주요 콘텐츠로 건너뛰기
HP Stream x360 11-p015wm Motherboard Replacement
필요한 것
  1. HP Stream x360 11-p015wm Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 HP Stream x360 11-p015wm Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Motherboard Replacement: 3 단계, 이미지 2개 중 1개 HP Stream x360 11-p015wm Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Motherboard Replacement: 4 단계, 이미지 2개 중 1개 HP Stream x360 11-p015wm Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    $3.99
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
  6. HP Stream x360 11-p015wm Motherboard Replacement: 6 단계, 이미지 3개 중 1개 HP Stream x360 11-p015wm Motherboard Replacement: 6 단계, 이미지 3개 중 2개 HP Stream x360 11-p015wm Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Unplug the wire attaching to the battery to the motherboard using the tweezers.
    • Remove the battery.
  7. HP Stream x360 11-p015wm Motherboard Replacement: 7 단계, 이미지 2개 중 1개 HP Stream x360 11-p015wm Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the six 3.5 mm screws from the silver plate cover with screwdriver JIS #00.
    • Remove the silver plate cover.
  8. HP Stream x360 11-p015wm Motherboard Replacement: 8 단계, 이미지 2개 중 1개 HP Stream x360 11-p015wm Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the four 3.5 mm screws from the metal arm using the JIS #00 screwdriver.
  9. HP Stream x360 11-p015wm Motherboard Replacement: 9 단계, 이미지 3개 중 1개 HP Stream x360 11-p015wm Motherboard Replacement: 9 단계, 이미지 3개 중 2개 HP Stream x360 11-p015wm Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Detach all remaining wires from the motherboard using the tweezers.
  10. HP Stream x360 11-p015wm Motherboard Replacement: 10 단계, 이미지 2개 중 1개 HP Stream x360 11-p015wm Motherboard Replacement: 10 단계, 이미지 2개 중 2개
  11. HP Stream x360 11-p015wm Motherboard Replacement: 11 단계, 이미지 2개 중 1개 HP Stream x360 11-p015wm Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the six 3.5 mm screws from the motherboard using the JIS #00 screwdriver.
    • Remove the motherboard.
결론
작성자
2다른 기여자 명과 함께
Meredith Buganski
회원 가입일: 11/11/19
151 평판
안내서 1개를 작성함
IUPUI, Team S2-G3, Stella Fall 2019 IUPUI, Team S2-G3, Stella Fall 2019 회원
IUPUI-STELLA-F19S2G3
3 회원들
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 16
전체 시간: 739
