소개
Use this guide to replace the power button, volume buttons, and ambient light sensor.
부품
지정된 부품이 없습니다.
In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
Use the edge of a plastic opening tool to flip up the retaining flap on the control button cable ZIF socket.
Pull the control button ribbon cable straight out of its socket on the motherboard.
다른 3명이 해당 안내서를 완성하였습니다.
