주요 콘텐츠로 건너뛰기
HP TouchPad Home Button Board Replacement
필요한 것
  1. HP TouchPad Home Button Board Replacement, Front Panel Assembly: 1 단계, 이미지 1/1
    • In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
    • The front panel is held in by seven clips (boxed in red) that are lightly anchored to the rear case. When you remove the front panel assembly, you are bound to break either the clips or their supports attached to the rear case. We will update this guide as we find replacement parts or a better method to remove the panel.
    • As you remove the front panel assembly, also be careful not to damage the ambient light sensor (boxed in yellow) or the two antennas (boxed in orange).
  2. HP TouchPad Home Button Board Replacement: 2 단계, 이미지 1/1
    • Insert a flat metal spudger in the gap between the rubber outer ring on the front panel assembly and the black plastic rear case near the USB connector.
    • Pry the front panel assembly up from the rear case, being careful not to damage the LCD or the glass panel.
    • As you work through the following steps, insert your metal spudger and pry the front panel up, but do not try to slide the spudger along the gap you're creating. Always remove your spudger, then insert it at another spot and pry upward.
  3. HP TouchPad Home Button Board Replacement: 3 단계, 이미지 1/2 HP TouchPad Home Button Board Replacement: 3 단계, 이미지 2/2
    • As in the previous step, use a spudger to pry the front panel up from the rear case along its long edge on the volume button side of the TouchPad.
    • Continue to pry the front panel assembly up along the volume button side of the TouchPad until there is a gap between it and the rear case.
  4. HP TouchPad Home Button Board Replacement: 4 단계, 이미지 1/2 HP TouchPad Home Button Board Replacement: 4 단계, 이미지 2/2
    • Pry up the front panel assembly along the top edge of the TouchPad.
    • Be careful not to damage the ambient light sensor or the upper antenna.
  5. HP TouchPad Home Button Board Replacement: 5 단계, 이미지 1/1
    • Pry up the front panel along the edge closest to the home screen button.
  6. HP TouchPad Home Button Board Replacement: 6 단계, 이미지 1/2 HP TouchPad Home Button Board Replacement: 6 단계, 이미지 2/2
    • Before lifting the free side of the front panel up from the rear case, you may need to release it from the plastic retaining clips holding it down.
    • Use your metal spudger to pull the stuck retaining clips away from the edge of the front panel.
  7. HP TouchPad Home Button Board Replacement: 7 단계, 이미지 1/1
    • After freeing the retaining clips, lift the front panel assembly away from the rear case.
    • Do not try to remove the front panel assembly from the TouchPad just yet, as it is still connected to the motherboard.
  8. HP TouchPad Home Button Board Replacement: 8 단계, 이미지 1/1
    • Use the attached black tab to pull the display data cable straight up and out of its socket on the motherboard.
    • Pull the cable upwards and not parallel to the face of the motherboard. Doing otherwise may damage the socket on the motherboard.
    • Take care not to pull on the ribbon that is stuck by adhesive to the bottom of cable you are detaching. It does not need to be disconnected.
  9. HP TouchPad Home Button Board Replacement: 9 단계, 이미지 1/3 HP TouchPad Home Button Board Replacement: 9 단계, 이미지 2/3 HP TouchPad Home Button Board Replacement: 9 단계, 이미지 3/3
    • Use your fingernail to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • Pull the digitizer ribbon cable straight out of its two sockets on the motherboard.
  10. HP TouchPad Home Button Board Replacement: 10 단계, 이미지 1/1
    • Remove the front panel assembly from the rear case assembly.
  11. HP TouchPad Home Button Board Replacement, Home Button Board: 11 단계, 이미지 1/2 HP TouchPad Home Button Board Replacement, Home Button Board: 11 단계, 이미지 2/2
    • Use a plastic opening tool to pry the home button board off the adhesive securing it to the front panel.
    • Be careful not to flex the board too much. It is very thin and delicate.
  12. HP TouchPad Home Button Board Replacement: 12 단계, 이미지 1/1
    • Remove the home button board from the front panel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Bookholt
586,635 평판
안내서 619개 작성하였습니다
댓글 한 개
Could anyone please let me know where I can buy the Home Button Board for the touchpad. Thanks.
Sao - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 13
전체 시간: 7,000
