소개
Use this guide to replace the antenna near the top left corner of your TouchPad.
도구
부품
지정된 부품이 없습니다.
In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
Use the edge of a plastic opening tool to flip up the retaining flap on the headphone jack ribbon cable ZIF socket.
Pull the headphone jack ribbon cable out of its socket and bend the cable away from the large piece of EMI foil stuck to the top speaker.
거의 끝나갑니다!
결론
