주요 콘텐츠로 건너뛰기
HP TouchSmart 15-r015dx Battery Replacement
  1. HP TouchSmart 15-r015dx Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off your laptop.
    • Ensure your laptop is off. Removing the battery while it is on may harm your laptop or yourself.
    • Flip over to view the bottom of the laptop in order to gain access the battery and the DVD±RW Drive.
  2. HP TouchSmart 15-r015dx Battery Replacement: 2 단계, 이미지 1/1
    • There are two battery release switches circled.
  3. HP TouchSmart 15-r015dx Battery Replacement: 3 단계, 이미지 1/1
    • slide release switches inward towards each other to release battery.
  4. HP TouchSmart 15-r015dx Battery Replacement: 4 단계, 이미지 1/1
    • after sliding the release switches, pull battery towards yourself to remove battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jacob Kleinsorge
회원 가입일: 01/30/15
2,093 평판
안내서 5개 작성하였습니다
USF Tampa, Team 16-4, Watkins Winter 2015 USF Tampa, Team 16-4, Watkins Winter 2015 회원
USFT-WATKINS-W15S16G4
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
I did all the steps but the laptop didn't turn on at all. I then unhooked the power, removed the new replacement battery, and plugged the power back in it turned on without the battery but it won't turn on with the new battery in it. What am I doing wrong? Thx for you time.
Sincerely, Don Mattia
ddavonn - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 2,210
