주요 콘텐츠로 건너뛰기
HP TouchSmart 15-r015dx Hard Drive Replacement
필요한 것
  1. HP TouchSmart 15-r015dx Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off your laptop.
    • Ensure your laptop is off. Removing the battery while it is on may harm your laptop or yourself.
    • Flip over to view the bottom of the laptop in order to gain access the battery and the DVD±RW Drive.
  2. HP TouchSmart 15-r015dx Hard Drive Replacement: 2 단계, 이미지 1/1
    • There are two battery release switches circled.
  3. HP TouchSmart 15-r015dx Hard Drive Replacement: 3 단계, 이미지 1/1
    • slide release switches inward towards each other to release battery.
  4. HP TouchSmart 15-r015dx Hard Drive Replacement: 4 단계, 이미지 1/1
    • after sliding the release switches, pull battery towards yourself to remove battery.
  5. HP TouchSmart 15-r015dx Hard Drive Replacement, DVD±RW Drive: 5 단계, 이미지 1/2 HP TouchSmart 15-r015dx Hard Drive Replacement, DVD±RW Drive: 5 단계, 이미지 2/2
    • There is one screw holding the DVD±RW Drive in place. Use the #00 screwdriver to remove the screw.
  6. HP TouchSmart 15-r015dx Hard Drive Replacement: 6 단계, 이미지 1/3 HP TouchSmart 15-r015dx Hard Drive Replacement: 6 단계, 이미지 2/3 HP TouchSmart 15-r015dx Hard Drive Replacement: 6 단계, 이미지 3/3
    • The DVD±RW Drive is here. Remove by gently pulling it straight out.
    • After removal of the DVD±RW Drive, two screws are exposed and must be removed.
  7. HP TouchSmart 15-r015dx Hard Drive Replacement, Keyboard: 7 단계, 이미지 1/2 HP TouchSmart 15-r015dx Hard Drive Replacement, Keyboard: 7 단계, 이미지 2/2
    • Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
    • One of the screws lies in the label.
  8. HP TouchSmart 15-r015dx Hard Drive Replacement: 8 단계, 이미지 1/3 HP TouchSmart 15-r015dx Hard Drive Replacement: 8 단계, 이미지 2/3 HP TouchSmart 15-r015dx Hard Drive Replacement: 8 단계, 이미지 3/3
    • Flip the laptop over to view the top and lift the screen up.
    • There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer.
    • Do NOT pull the keyboard up more than 2-3 inches as there is a film-material connecting the keyboard to the laptop.
  9. HP TouchSmart 15-r015dx Hard Drive Replacement: 9 단계, 이미지 1/3 HP TouchSmart 15-r015dx Hard Drive Replacement: 9 단계, 이미지 2/3 HP TouchSmart 15-r015dx Hard Drive Replacement: 9 단계, 이미지 3/3
    • There is a small black latch holding the film-material in place.
    • Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard.
    • There are tiny prongs on the ribbon; it must be carefully removed and upon re-installation the prongs must be lined up exactly in each tiny track in order for the keyboard to work.
  10. HP TouchSmart 15-r015dx Hard Drive Replacement, Hard Drive: 10 단계, 이미지 1/1
    • Flip the laptop over to view the bottom and remove the remaining screws from the bottom.
    • There are 2 screws located underneath the covers.
  11. HP TouchSmart 15-r015dx Hard Drive Replacement: 11 단계, 이미지 1/2 HP TouchSmart 15-r015dx Hard Drive Replacement: 11 단계, 이미지 2/2
    • Flip your laptop over to view top and open it.
    • Remove the four screws and the two wires before removing the base of the laptop.
    • The metal prongs that wires fit onto stay attached to the computer and can be easily bent when trying to remove or place the plastic piece on to secure the wire. Also pay attention to how the plastic piece looks when you take them off (i.e. which side is up and facing out).
  12. HP TouchSmart 15-r015dx Hard Drive Replacement: 12 단계, 이미지 1/1
    • Use your plastic opening tool to pry the base of the laptop off.
  13. HP TouchSmart 15-r015dx Hard Drive Replacement: 13 단계, 이미지 1/3 HP TouchSmart 15-r015dx Hard Drive Replacement: 13 단계, 이미지 2/3 HP TouchSmart 15-r015dx Hard Drive Replacement: 13 단계, 이미지 3/3
    • There are two screws holding the hard drive in place. Remove these screws.
    • Remove the hard drive by pulling it to the right like shown.
결론
To reassemble your device and complete the hard drive replacement, please follow these instructions in reverse order.
다른 37명이 해당 안내서를 완성하였습니다.
Jacob Kleinsorge
회원 가입일: 01/30/15
2,093 평판
안내서 5개 작성하였습니다
USF Tampa, Team 16-4, Watkins Winter 2015 USF Tampa, Team 16-4, Watkins Winter 2015 회원
USFT-WATKINS-W15S16G4
4 회원들
안내서 6개 작성하였습니다
댓글 3개
Two things to add:
1. The two screws hidden under the DVD drive on the edge of the case must be removed.
2. It's easier to unlatch the ribbons for the keyboard, trackpad, and power button than it is to try and work around them. There are holes in the laptop base right over the ribbon connectors, so it's easy to re-connect them.
nullisland - 답글
I don't have the screws that hold the hard drive in place. Is there any way to get them seperatly?
Anonnymuz example - 답글
This thing is impossible to take apart I swear to god. I ended up just ripping it apart to remove the HDD and screen.
MitW - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 28
전체 시간: 30,967
