주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
HP TouchSmart 15-r015dx Keyboard Replacement
필요한 것
  1. HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
    • One of the screws lies in the label.
  2. HP TouchSmart 15-r015dx Keyboard Replacement: 2 단계, 이미지 1/3 HP TouchSmart 15-r015dx Keyboard Replacement: 2 단계, 이미지 2/3 HP TouchSmart 15-r015dx Keyboard Replacement: 2 단계, 이미지 3/3
    • Flip the laptop over to view the top and lift the screen up.
    • There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer.
    • Do NOT pull the keyboard up more than 2-3 inches as there is a film-material connecting the keyboard to the laptop.
  3. HP TouchSmart 15-r015dx Keyboard Replacement: 3 단계, 이미지 1/3 HP TouchSmart 15-r015dx Keyboard Replacement: 3 단계, 이미지 2/3 HP TouchSmart 15-r015dx Keyboard Replacement: 3 단계, 이미지 3/3
    • There is a small black latch holding the film-material in place.
    • Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard.
    • There are tiny prongs on the ribbon; it must be carefully removed and upon re-installation the prongs must be lined up exactly in each tiny track in order for the keyboard to work.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jacob Kleinsorge
회원 가입일: 01/30/15
2,093 평판
안내서 5개 작성하였습니다
USF Tampa, Team 16-4, Watkins Winter 2015 USF Tampa, Team 16-4, Watkins Winter 2015 회원
USFT-WATKINS-W15S16G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 2,942
