소개
The HP TouchSmart 15-r015dx has a standard laptop motherboard.
도구
부품
지정된 부품이 없습니다.
Flip over to view the bottom of the laptop in order to gain access the battery and the DVD±RW Drive.
There is one screw holding the DVD±RW Drive in place. Use the #00 screwdriver to remove the screw.
Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
Flip the laptop over to view the bottom and remove the remaining screws from the bottom.
There are 3 screws holding the motherboard in place.
Unscrew the screws to release the motherboard.
다른 4명이 해당 안내서를 완성하였습니다.
