주요 콘텐츠로 건너뛰기
소개
The HP TouchSmart 15-r015dx has 4 GB of RAM.
부품
지정된 부품이 없습니다.
  1. Turn off your laptop.
    • Turn off your laptop.
    • Ensure your laptop is off. Removing the battery while it is on may harm your laptop or yourself.
    • Flip over to view the bottom of the laptop in order to gain access the battery and the DVD±RW Drive.
  2. There are two battery release switches circled, slide both switches inward to release and remove the battery. There are two battery release switches circled, slide both switches inward to release and remove the battery. There are two battery release switches circled, slide both switches inward to release and remove the battery.
    • There are two battery release switches circled, slide both switches inward to release and remove the battery.
  3. There is one screw holding the DVD±RW Drive in place. Use the #00 screwdriver to remove the screw. There is one screw holding the DVD±RW Drive in place. Use the #00 screwdriver to remove the screw.
    • There is one screw holding the DVD±RW Drive in place. Use the #00 screwdriver to remove the screw.
  4. The DVD±RW Drive is here. Remove by gently pulling it straight out. After removal of the DVD±RW Drive, two screws are exposed and must be removed. After removal of the DVD±RW Drive, two screws are exposed and must be removed.
    • The DVD±RW Drive is here. Remove by gently pulling it straight out.
    • After removal of the DVD±RW Drive, two screws are exposed and must be removed.
  5. Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard. One of the screws lies in the label.
    • Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
    • One of the screws lies in the label.
  6. Flip the laptop over to view the top and lift the screen up. There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer. Do NOT pull the keyboard up more than 2-3 inches as there is a film-material connecting the keyboard to the laptop.
    • Flip the laptop over to view the top and lift the screen up.
    • There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer.
    • Do NOT pull the keyboard up more than 2-3 inches as there is a film-material connecting the keyboard to the laptop.
  7. There is a small black latch holding the film-material in place. Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard. There are tiny prongs on the ribbon; it must be carefully removed and upon re-installation the prongs must be lined up exactly in each tiny track in order for the keyboard to work.
    • There is a small black latch holding the film-material in place.
    • Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard.
    • There are tiny prongs on the ribbon; it must be carefully removed and upon re-installation the prongs must be lined up exactly in each tiny track in order for the keyboard to work.
  8. Flip the laptop over to view the bottom and remove the remaining screws from the bottom.
    • Flip the laptop over to view the bottom and remove the remaining screws from the bottom.
    • There are 2 screws located underneath the covers.
  9. Flip your laptop over to view top and open it. Remove the four screws and the two wires before removing the base of the laptop.
    • Flip your laptop over to view top and open it.
    • Remove the four screws and the two wires before removing the base of the laptop.
    • The metal prongs that wires fit onto stay attached to the computer and can be easily bent when trying to remove or place the plastic piece on to secure the wire. Also pay attention to how the plastic piece looks when you take them off (i.e. which side is up and facing out).
  10. Use your plastic opening tool to pry the base of the laptop off.
    • Use your plastic opening tool to pry the base of the laptop off.
  11. There are two screws holding the hard drive in place. Remove these screws. Remove the hard drive by pulling it to the right like shown. Remove the hard drive by pulling it to the right like shown.
    • There are two screws holding the hard drive in place. Remove these screws.
    • Remove the hard drive by pulling it to the right like shown.
  12. There are 3 screws holding the motherboard in place. Unscrew the screws to release the motherboard. Unscrew the screws to release the motherboard.
    • There are 3 screws holding the motherboard in place.
    • Unscrew the screws to release the motherboard.
  13. There are several wires that need to be disconnected from the motherboard. Remove the wires carefully. Remove the wires carefully.
    • There are several wires that need to be disconnected from the motherboard.
    • Remove the wires carefully.
  14. After removing all the wires, pull the motherboard out.
    • After removing all the wires, pull the motherboard out.
  15. Put the motherboard on a hard, flat surface to avoid damaging it.
    • Put the motherboard on a hard, flat surface to avoid damaging it.
    • The RAM is marked in red.
  16. There are two switches holding the RAM in place that need to be moved. After the switches are released, simply pull the RAM up as shown.
    • There are two switches holding the RAM in place that need to be moved.
    • After the switches are released, simply pull the RAM up as shown.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Jacob Kleinsorge
회원 가입일: 2015년 01월 30일
2,051 평판
안내서 5개 작성하였습니다
USF Tampa, Team 16-4, Watkins Winter 2015 USF Tampa, Team 16-4, Watkins Winter 2015 회원
USFT-WATKINS-W15S16G4
4 회원들
안내서 6개 작성하였습니다
댓글 3개
Cool, thanks guys. I used the guide successfully to upgrade the RAM on my HP 15-r033na Notebook. It would have taken ages without your help! A really tough way to reach the memory.
I wonder if the second DIMM slot is usable. The specs I've found says this board only takes one card, so maybe the second is disconnected.
Tim Ellison - 답글
Did you ever get an answer on this? Did your upgrade improve performance at all? Seems like 20 steps x 2 should only be undertaken if there's a serious boost at the end of that tunnel. Thoughts?
Note that my system now has 4GB in slot 1 and 2GB additional in slot 2. Still, I constantly run out of RAM.
Thanks!
Daniel - HP TS 15 owner
Daniel Robin -
Thanks so much for this guide. I’d found my PC’s manual/repair guide online (it’s an HP 15-r011dx) but the instructions were much more cumbersome. Your guide is excellent, and now with twice the RAM, I feel like I have a totally different PC!
The whole upgrade was much more fidgety though than any Mac I’ve ever worked on, and so strange that HP puts the RAM chip on the motherboard. Crazy… It’s like having to do a root canal to brush your teeth!
Traveled Woman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 49
전체 시간: 5,029
