주요 콘텐츠로 건너뛰기
HP TouchSmart 15-r015dx Screen Replacement
필요한 것
  1. HP TouchSmart 15-r015dx Screen Replacement, Screen: 1 단계, 이미지 1/3 HP TouchSmart 15-r015dx Screen Replacement, Screen: 1 단계, 이미지 2/3 HP TouchSmart 15-r015dx Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Acquire the metal spudger and a Precision Magnetized Driver with J1 size bit.
    • Flip your HP TouchSmart 15 over.
  2. HP TouchSmart 15-r015dx Screen Replacement: 2 단계, 이미지 1/3 HP TouchSmart 15-r015dx Screen Replacement: 2 단계, 이미지 2/3 HP TouchSmart 15-r015dx Screen Replacement: 2 단계, 이미지 3/3
    • Locate tabs on the underside of the laptop.
    • Push both tabs towards the center of the laptop and pull away to remove battery.
  3. HP TouchSmart 15-r015dx Screen Replacement: 3 단계, 이미지 1/3 HP TouchSmart 15-r015dx Screen Replacement: 3 단계, 이미지 2/3 HP TouchSmart 15-r015dx Screen Replacement: 3 단계, 이미지 3/3
    • Take the sharp end of the pry tool and pop out the black screw cover.
    • Repeat on opposite side.
  4. HP TouchSmart 15-r015dx Screen Replacement: 4 단계, 이미지 1/3 HP TouchSmart 15-r015dx Screen Replacement: 4 단계, 이미지 2/3 HP TouchSmart 15-r015dx Screen Replacement: 4 단계, 이미지 3/3
    • Take the Precision Magnetized Driver with J1 size bit and unscrew the screw.
  5. HP TouchSmart 15-r015dx Screen Replacement: 5 단계, 이미지 1/3 HP TouchSmart 15-r015dx Screen Replacement: 5 단계, 이미지 2/3 HP TouchSmart 15-r015dx Screen Replacement: 5 단계, 이미지 3/3
    • Using the pry tool, begin to separate the touchscreen from the plastic backing.
  6. HP TouchSmart 15-r015dx Screen Replacement: 6 단계, 이미지 1/3 HP TouchSmart 15-r015dx Screen Replacement: 6 단계, 이미지 2/3 HP TouchSmart 15-r015dx Screen Replacement: 6 단계, 이미지 3/3
    • Close the laptop and flip it over once again.
    • Continue to pry the touchscreen from the plastic backing in the hinged area of the laptop.
  7. HP TouchSmart 15-r015dx Screen Replacement: 7 단계, 이미지 1/3 HP TouchSmart 15-r015dx Screen Replacement: 7 단계, 이미지 2/3 HP TouchSmart 15-r015dx Screen Replacement: 7 단계, 이미지 3/3
    • Flip over the laptop and open it.
    • Pull up on the separated touchscreen while pulling it away from the plastic backing.
    • Be careful while laying down the touchscreen to not pull the connection point.
    • Lay the touchscreen on the keyboard facedown.
  8. HP TouchSmart 15-r015dx Screen Replacement: 8 단계, 이미지 1/3 HP TouchSmart 15-r015dx Screen Replacement: 8 단계, 이미지 2/3 HP TouchSmart 15-r015dx Screen Replacement: 8 단계, 이미지 3/3
    • Locate the connection point.
    • Slowly and carefully peel off.
  9. HP TouchSmart 15-r015dx Screen Replacement: 9 단계, 이미지 1/2 HP TouchSmart 15-r015dx Screen Replacement: 9 단계, 이미지 2/2
    • Isolate the touchscreen from the keyboard.
  10. HP TouchSmart 15-r015dx Screen Replacement: 10 단계, 이미지 1/3 HP TouchSmart 15-r015dx Screen Replacement: 10 단계, 이미지 2/3 HP TouchSmart 15-r015dx Screen Replacement: 10 단계, 이미지 3/3
    • Begin by peeling off the black adhesive tape using the pry tool.
    • Once adhesive tape is removed, use the pry tool to remove the tab in the corner. Repeat in each corner.
  11. HP TouchSmart 15-r015dx Screen Replacement: 11 단계, 이미지 1/3 HP TouchSmart 15-r015dx Screen Replacement: 11 단계, 이미지 2/3 HP TouchSmart 15-r015dx Screen Replacement: 11 단계, 이미지 3/3
    • Using the sharp end of the pry tool, separate the plastic from the screen.
  12. HP TouchSmart 15-r015dx Screen Replacement: 12 단계, 이미지 1/1
    • Now it is time to reassemble your device with a new screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Gabriel Terrasas
회원 가입일: 11/30/17
304 평판
안내서 1개 작성함
Coast Union High School, Team S1-G1, Hartzell Fall 2017 Coast Union High School, Team S1-G1, Hartzell Fall 2017 회원
CUHS-HARTZELL-F17S1G1
2 회원들
안내서 1개 작성하였습니다
댓글 한 개
Amazing work. I would not change a thing.
Dan Hartzell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,189
