주요 콘텐츠로 건너뛰기
HP Touchsmart 600 1052 CPU Replacement
  1. HP Touchsmart 600 1052 CPU Replacement, Remove back cover: 1 단계, 이미지 3개 중 1개 HP Touchsmart 600 1052 CPU Replacement, Remove back cover: 1 단계, 이미지 3개 중 2개 HP Touchsmart 600 1052 CPU Replacement, Remove back cover: 1 단계, 이미지 3개 중 3개
    • Nearly every screw in this computer uses a Torx bit, but they also have a slit that allows them to be removed with a flat-head screwdriver as well.
    • Flip the computer screen down, and flip the cover on the stand up.
    • Remove the screw and slide the panel down to remove the cover.
  2. HP Touchsmart 600 1052 CPU Replacement, Remove the stand: 2 단계, 이미지 2개 중 1개 HP Touchsmart 600 1052 CPU Replacement, Remove the stand: 2 단계, 이미지 2개 중 2개
    • Unscrew the 4 screws holding the stand to the computer and pull the stand down to remove it.
  3. HP Touchsmart 600 1052 CPU Replacement, Remove bezels (Part One): 3 단계, 이미지 1개 중 1개
    • Remove the bezel covering the ports
  4. HP Touchsmart 600 1052 CPU Replacement, Remove bezels (Part Two): 4 단계, 이미지 3개 중 1개 HP Touchsmart 600 1052 CPU Replacement, Remove bezels (Part Two): 4 단계, 이미지 3개 중 2개 HP Touchsmart 600 1052 CPU Replacement, Remove bezels (Part Two): 4 단계, 이미지 3개 중 3개
    • Pull up on the bezel from the bottom. As long as you are careful, you should be able to remove them without breaking any clips
  5. HP Touchsmart 600 1052 CPU Replacement, Remove feet: 5 단계, 이미지 1개 중 1개
    • Unscrew and pull the foot towards you. Repeat on other side.
  6. HP Touchsmart 600 1052 CPU Replacement, Remove DVD cover: 6 단계, 이미지 2개 중 1개 HP Touchsmart 600 1052 CPU Replacement, Remove DVD cover: 6 단계, 이미지 2개 중 2개
    • Pull up on the little tab and remove the DVD cover
  7. HP Touchsmart 600 1052 CPU Replacement, Remove back panel: 7 단계, 이미지 3개 중 1개 HP Touchsmart 600 1052 CPU Replacement, Remove back panel: 7 단계, 이미지 3개 중 2개 HP Touchsmart 600 1052 CPU Replacement, Remove back panel: 7 단계, 이미지 3개 중 3개
    • CHECK ALL THREE PHOTOS TO REMOVE ALL SCREW
    • Remove all 13 screws
  8. HP Touchsmart 600 1052 CPU Replacement, Remove back (cont.): 8 단계, 이미지 2개 중 1개 HP Touchsmart 600 1052 CPU Replacement, Remove back (cont.): 8 단계, 이미지 2개 중 2개
    • Pull up on the bottom of the panel and hinge it.
    • It will come off, set it aside
  9. HP Touchsmart 600 1052 CPU Replacement, Remove power cover: 9 단계, 이미지 2개 중 1개 HP Touchsmart 600 1052 CPU Replacement, Remove power cover: 9 단계, 이미지 2개 중 2개
    • Unscrew both screws and remove the cover
  10. HP Touchsmart 600 1052 CPU Replacement, Unscrew panel: 10 단계, 이미지 1개 중 1개
    • Unscrew the nine screws holding the panel in.
  11. HP Touchsmart 600 1052 CPU Replacement, Pulling off the cover: 11 단계, 이미지 1개 중 1개
    • Pull the cover towards the top left to remove it
  12. HP Touchsmart 600 1052 CPU Replacement: 12 단계, 이미지 1개 중 1개
    • Unscrew CPU fan
    • DO NOT TRY AND REMOVE THE FAN. THE HEAT PIPE IS ON TOP OF THE CPU
  13. HP Touchsmart 600 1052 CPU Replacement, Removing the CPU cooler: 13 단계, 이미지 2개 중 1개 HP Touchsmart 600 1052 CPU Replacement, Removing the CPU cooler: 13 단계, 이미지 2개 중 2개
    • Unscrew the plate over the CPU
    • It uses a small phillips head, one of the only non torx bits in the computer
    • After unscrewing the plate, flip the fan off of the CPU
  14. HP Touchsmart 600 1052 CPU Replacement: 14 단계, 이미지 2개 중 1개 HP Touchsmart 600 1052 CPU Replacement: 14 단계, 이미지 2개 중 2개
    • Unlock the socket and remove the CPU
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
NahDoesntExist
회원 가입일: 08/13/23
352 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 5
전체 시간: 120
