주요 콘텐츠로 건너뛰기
HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement
필요한 것
  1. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: 1 단계, 이미지 1/3 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: 1 단계, 이미지 2/3 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: 1 단계, 이미지 3/3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Shell: 2 단계, 이미지 1/2 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Shell: 2 단계, 이미지 2/2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: 3 단계, 이미지 1/3 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: 3 단계, 이미지 2/3 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: 3 단계, 이미지 3/3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: 4 단계, 이미지 1/2 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: 4 단계, 이미지 2/2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Clement Cheung
회원 가입일: 01/24/19
643 평판
안내서 5개 작성하였습니다
Cal Poly, Team S18-G5, White Winter 2019 Cal Poly, Team S18-G5, White Winter 2019 회원
CPSU-WHITE-W19S18G5
2 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 17
전체 시간: 672
