주요 콘텐츠로 건너뛰기
HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement
필요한 것
  1. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Batteries: 1 단계, 이미지 3개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Batteries: 1 단계, 이미지 3개 중 2개 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Batteries: 1 단계, 이미지 3개 중 3개
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Shell: 2 단계, 이미지 2개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Shell: 2 단계, 이미지 2개 중 2개
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 3 단계, 이미지 3개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 3 단계, 이미지 3개 중 2개 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 3 단계, 이미지 3개 중 3개
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 4 단계, 이미지 2개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 4 단계, 이미지 2개 중 2개
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Small Circuit Board: 5 단계, 이미지 2개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Small Circuit Board: 5 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
  6. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 6 단계, 이미지 3개 중 1개 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 6 단계, 이미지 3개 중 2개 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Clement Cheung
회원 가입일: 01/24/19
643 평판
안내서 5개를 작성함
Cal Poly, Team S18-G5, White Winter 2019 Cal Poly, Team S18-G5, White Winter 2019 회원
CPSU-WHITE-W19S18G5
2 회원들
안내서 14개를 작성함
1가이드 댓글
Where would I be able to buy a replacement small board?
Emerald Wolf - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 770
