주요 콘텐츠로 건너뛰기
HP Z2 Mini G3 Access Panel Replacement
  1. HP Z2 Mini G3 Access Panel Replacement, Access Panel: 1 단계, 이미지 1개 중 1개
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 Access Panel Replacement: 2 단계, 이미지 2개 중 1개 HP Z2 Mini G3 Access Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 Access Panel Replacement: 3 단계, 이미지 2개 중 1개 HP Z2 Mini G3 Access Panel Replacement: 3 단계, 이미지 2개 중 2개
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
결론
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 31
전체 시간: 1,247
