주요 콘텐츠로 건너뛰기
HP ZBOOK 15 G5 LCD Replacement
  1. HP ZBOOK 15 G5 LCD Replacement, Opening the Bottom Panel: 1 단계, 이미지 1개 중 1개
    • Find the bottom panel locking mechanism
    • Move the switch to the right to unlock and slide it in a downwards fashion
  2. HP ZBOOK 15 G5 LCD Replacement, Removing the Battery: 2 단계, 이미지 1개 중 1개
    • Slide the battery latches to the right to loosen the battery
    • Remove the battery and place it to the side
  3. HP ZBOOK 15 G5 LCD Replacement, Removing the Bottom Case: 3 단계, 이미지 1개 중 1개
    • Remove the keyboard screws
    • Remove these screws with a T8 screwdriver
    • Remove these screws with a philips screwdriver
    • Once they are removed, carefully lift up the bottom case
  4. HP ZBOOK 15 G5 LCD Replacement, Removing SSD and LCD Connector Cover: 4 단계, 이미지 1개 중 1개
    • Unscrew SSD screw and slide the SSD out
    • Remove these screws and place the LCD connector cover to the side
    • Disconnect all of the motherboard connectors
  5. HP ZBOOK 15 G5 LCD Replacement, Removing the LCD: 5 단계, 이미지 1개 중 1개
    • Unscrew the 6 LCD screws to the top left and right
    • Once removed, carefully remove the LCD
    • Tip: Remove two screws from each side and then place the laptop on it's side. Unscrew the final two and separate the LCD and Top Case
    • Screw the new LCD in and make sure to connect all of the LCD connectors
    • Screw the bottom case back onto the laptop
    • Connect the battery and put the battery cover back into place
결론
Once the repair had been done. Call the user and let them know their laptop is ready for pick-up
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ved Pitre
회원 가입일: 10/30/19
1,128 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 132
전체 시간: 9,005
