주요 콘텐츠로 건너뛰기
HP ZBook 15 Keyboard Replacement
필요한 것
  1. HP ZBook 15 Keyboard Replacement, Battery: 1 단계, 이미지 1/2 HP ZBook 15 Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Keyboard Replacement, Back Cover: 2 단계, 이미지 1/1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Remove the two 16mm screws with a Phillips #0 screwdriver.
    • There are two sets of threads to get past. Once unscrewed from the first thread, lift the screw up until it hits the next set and begin unscrewing again.
  4. HP ZBook 15 Keyboard Replacement: 4 단계, 이미지 1/3 HP ZBook 15 Keyboard Replacement: 4 단계, 이미지 2/3 HP ZBook 15 Keyboard Replacement: 4 단계, 이미지 3/3
    • Do not try to pry the keyboard from the bottom. The keyboard is attached by clips on the left, top, and right side. Metal inserts on the bottom side lock the keyboard in place until they are slid up and out.
    • Be careful not to scratch or chip the computer when prying. If you have a plastic tool that is long enough to gain leverage, use that instead of a metal tool.
    • There are ribbons secured underneath so be careful not to pull the keyboard out too hard, breaking the connections to the ribbons.
    • Flip the laptop over so the keyboard is visible.
    • Insert the spudger under the left side of the keyboard.
    • Carefully raise the side of the keyboard and firmly pull the left corner of the keyboard until it pops up.
    • Run your fingers under the edges of the keyboard along the top edge of the keyboard, from the top left to the top right, to separate it from the remaining clips.
    • Carefully slide the keyboard up toward the screen and out of the case.
  5. HP ZBook 15 Keyboard Replacement: 5 단계, 이미지 1/3 HP ZBook 15 Keyboard Replacement: 5 단계, 이미지 2/3 HP ZBook 15 Keyboard Replacement: 5 단계, 이미지 3/3
    • Gently lift the two tabs on either side of the black ribbon with a spudger until the ribbon comes loose.
    • Disconnect the black ribbon by pulling the blue tab hanging off of it.
    • Repeat with the white ribbon.
결론
다른 33명이 해당 안내서를 완성하였습니다.
Grant Terris
회원 가입일: 01/30/15
2,834 평판
안내서 12개 작성하였습니다
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G43
4 회원들
안내서 15개 작성하였습니다
댓글 13개
I found that if you remove the optical drive, you have access to push the keyboard form the back to disengage the side with the number pad.
bryanholder81 - 답글
I agree with Bryan...much easier to start that way. Pushing from the back will disengage the top right corner (seen from the user position)
advrider - 답글
In addition to the comments about pushing the keyboard out after removing the optical drive (which is actually the documented way of removing the keyboard) I'd add that the bit about "There are two sets of threads to get past. Once unscrewed from the first thread, lift the screw up until it hits the next set and begin unscrewing again." is incorrect. The screws are deliberately designed to be self retaining. You only need to unscrew it until the screw turns freely (i.e. not fully).
Dominic Cioccarelli - 답글
please, will they have the part number of this keyboard ?, it hurt me and I saw the steps that are followed to extract it, and replace it, but I can not find the part number of the keyboard replacement, if someone could have it tell me which is please?
cesar rios - 답글
Go to partsurfer.hp.com with the p/n of the machine and you'll get the exact part number of the keyboard you need
Johan Rios - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 49
30일 전: 182
전체 시간: 66,732
