주요 콘텐츠로 건너뛰기
HP ZBook 15 Optical Drive Replacement
필요한 것
  1. HP ZBook 15 Optical Drive Replacement, Battery: 1 단계, 이미지 1/2 HP ZBook 15 Optical Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Optical Drive Replacement, Back Cover: 2 단계, 이미지 1/1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 1/1
    • Unscrew the captive screw shown near the battery compartment with a Phillips #0 screwdriver.
    • The screw does not come out all the way and stays attached to the computer.
  4. HP ZBook 15 Optical Drive Replacement: 4 단계, 이미지 1/3 HP ZBook 15 Optical Drive Replacement: 4 단계, 이미지 2/3 HP ZBook 15 Optical Drive Replacement: 4 단계, 이미지 3/3
    • Push outward on the metal optical drive tab with a metal spudger to unlock the drive from its position in the case.
    • Once the drive is protruding from the side of the computer, pull it the rest of the way out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Grant Terris
회원 가입일: 01/30/15
2,834 평판
안내서 12개 작성하였습니다
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G43
4 회원들
안내서 15개 작성하였습니다
댓글 2개
Mine won't come out and now I think my silver tab is bent. Please help me!
Sajid - 답글
Oddly enough, mine came with no DVD drive but a blanking… thing, which seems to be a trimmed-down version of this official adapter (HP SPS 734298-001) without the electronics. I bought a cheap chinese ODD caddy, tore it down and salvaged the logic board. Luckily, I got everything lined up after a few adjustments (the chinese logic board is a bit longer than the HP one).
Now I’m rocking an extra drive bay without paying the $75 some shops ask for the official one.
I use it as swappable storage (not hot-swappable, mind you) . Very handy for doing drive imaging and cloning when working as an IT technician out in the field.
Luis Alejandro Araúz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 23
전체 시간: 6,794
