주요 콘텐츠로 건너뛰기
HP ZBook 15 SSD Cache Replacement
필요한 것
  1. HP ZBook 15 SSD Cache Replacement, Battery: 1 단계, 이미지 1/2 HP ZBook 15 SSD Cache Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 SSD Cache Replacement, Back Cover: 2 단계, 이미지 1/1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 SSD Cache Replacement, SSD Cache: 3 단계, 이미지 1/2 HP ZBook 15 SSD Cache Replacement, SSD Cache: 3 단계, 이미지 2/2
    • Remove the two 3 mm screws with a Phillips #0 screwdriver.
    • Remove the Solid State Cache by pulling the module up and out.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Grant Terris
회원 가입일: 01/30/15
2,834 평판
안내서 12개 작성하였습니다
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G43
4 회원들
안내서 15개 작성하였습니다
댓글 2개
Does it create a seprate volume drive by inserting the mSata SSD to install Operating System on it?
Reza Sajedi - 답글
Remember, this machine is from 2013, a time when SSDs were still hella expensive! That’s why the mSATA drive is refered to as a “cache” drive: they were so small they were only good for that. A stock, untouched Zbook g1/g2 might still come with a small (32GB) mSATA SSD configured as cache in the OS.
That doesn’t mean you can’t use the mSATA drive as your main OS drive, and that’s what I’ve been doing for years without a hint of trouble. You can easily find a high capacity mSATA SSD and put your OS and I/O-intensive programs on it. The Zbook will purr along nicely.
Luis Alejandro Araúz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 47
전체 시간: 12,002
