주요 콘텐츠로 건너뛰기
HP dv5-1125nr Battery Replacement
필요한 것
  1. HP dv5-1125nr Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Battery Replacement: 2 단계, 이미지 1/1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
결론
To reassemble your device, follow these instructions in reverse order. Note the release switch does not need to be held down to replace the battery.
다른 4명이 해당 안내서를 완성하였습니다.
Nick Loey
회원 가입일: 04/01/14
1,688 평판
안내서 8개 작성하였습니다
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014 회원
CPSU-REGAN-S14S9G15
4 회원들
안내서 10개 작성하였습니다
댓글 2개
Can I return a battery if it does not fit? GLOPAM2013@YAHOO.COM
glopam2013 - 답글
what is your return policy?
glopam2013 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,197
