소개
Removing the battery is usually the first step to reaching the guts of any laptop. HP has utilized a simple one-switch release system to aid in the removal of the battery.
필요한 것
To reassemble your device, follow these instructions in reverse order. Note the release switch does not need to be held down to replace the battery.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
Can I return a battery if it does not fit? GLOPAM2013@YAHOO.COM
glopam2013 - 답글
what is your return policy?
glopam2013 - 답글
