주요 콘텐츠로 건너뛰기
HP dv5-1125nr Disk Drive Replacement
필요한 것
  1. HP dv5-1125nr Disk Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Disk Drive Replacement: 2 단계, 이미지 1/1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Disk Drive Replacement, Disk Drive: 3 단계, 이미지 1/2 HP dv5-1125nr Disk Drive Replacement, Disk Drive: 3 단계, 이미지 2/2
    • Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
    • Remove the CMOS panel cover.
  4. HP dv5-1125nr Disk Drive Replacement: 4 단계, 이미지 1/3 HP dv5-1125nr Disk Drive Replacement: 4 단계, 이미지 2/3 HP dv5-1125nr Disk Drive Replacement: 4 단계, 이미지 3/3
    • The optical drive is now ready for removal. Using a plastic removal tool, lift the optical drive away from your computer.
    • Using your hands, slide the remainder of the drive out of the computer.
결론
Nick Loey
회원 가입일: 04/01/14
1,688 평판
안내서 8개 작성하였습니다
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014 회원
CPSU-REGAN-S14S9G15
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 733
