주요 콘텐츠로 건너뛰기
HP dv5-1125nr RAM Replacement
필요한 것
  1. HP dv5-1125nr RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr RAM Replacement: 2 단계, 이미지 1/1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr RAM Replacement, RAM: 3 단계, 이미지 1/1
    • Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr RAM Replacement: 4 단계, 이미지 1/2 HP dv5-1125nr RAM Replacement: 4 단계, 이미지 2/2
    • Remove the RAM cover to reveal the module's underneath.
  5. HP dv5-1125nr RAM Replacement: 5 단계, 이미지 1/3 HP dv5-1125nr RAM Replacement: 5 단계, 이미지 2/3 HP dv5-1125nr RAM Replacement: 5 단계, 이미지 3/3
    • Make sure to ground yourself before touching the RAM modules; they are very sensitive to static electricity.
    • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
    • Once the module is released, gently pull the module upwards.
    • Repeat for the RAM module underneath the first one.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Nick Loey
회원 가입일: 04/01/14
1,688 평판
안내서 8개 작성하였습니다
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014 회원
CPSU-REGAN-S14S9G15
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 974
