주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
HP dv5-1125nr WLAN Card Replacement
필요한 것
  1. HP dv5-1125nr WLAN Card Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr WLAN Card Replacement: 2 단계, 이미지 1/1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr WLAN Card Replacement, Hard Drive: 3 단계, 이미지 1/2 HP dv5-1125nr WLAN Card Replacement, Hard Drive: 3 단계, 이미지 2/2
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr WLAN Card Replacement: 4 단계, 이미지 1/1
    • Remove the plastic hard drive cover.
  5. HP dv5-1125nr WLAN Card Replacement: 5 단계, 이미지 1/2 HP dv5-1125nr WLAN Card Replacement: 5 단계, 이미지 2/2
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  6. HP dv5-1125nr WLAN Card Replacement: 6 단계, 이미지 1/2 HP dv5-1125nr WLAN Card Replacement: 6 단계, 이미지 2/2
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  7. HP dv5-1125nr WLAN Card Replacement: 7 단계, 이미지 1/2 HP dv5-1125nr WLAN Card Replacement: 7 단계, 이미지 2/2
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
  8. HP dv5-1125nr WLAN Card Replacement, WLAN Card: 8 단계, 이미지 1/1
    • Locate the wireless card and the two wires attached to it.
    • Caution: Prying on the WLAN card wires in the wrong direction could damage your wireless card. Make sure to lift straight up when removing the wires.
    • Using a plastic spudger tool, carefully lift up on each wire connecting the card to unsnap the connectors.
  9. HP dv5-1125nr WLAN Card Replacement: 9 단계, 이미지 1/2 HP dv5-1125nr WLAN Card Replacement: 9 단계, 이미지 2/2
    • Locate the 2.5mm Phillips screw on the corner of the WLAN card and remove it using a Phillips #000 screwdriver.
  10. HP dv5-1125nr WLAN Card Replacement: 10 단계, 이미지 1/2 HP dv5-1125nr WLAN Card Replacement: 10 단계, 이미지 2/2
    • Upon removing the screw, the WLAN card will pop up. Keeping a natural angle, slide the card out of the slot.
    • The card is now free from your computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cory Mayer
회원 가입일: 04/01/14
891 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014 회원
CPSU-REGAN-S14S9G15
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 1,152
