주요 콘텐츠로 건너뛰기
HP eStation Zeen Motherboard Replacement
필요한 것
  1. HP eStation Zeen Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 HP eStation Zeen Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 HP eStation Zeen Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Remove the screw caps using the metal spudger.
    • Remove the four 6mm Phillips screws using the Phillips #0 screwdriver.
  2. HP eStation Zeen Motherboard Replacement: 2 단계, 이미지 1/3 HP eStation Zeen Motherboard Replacement: 2 단계, 이미지 2/3 HP eStation Zeen Motherboard Replacement: 2 단계, 이미지 3/3
    • Unclip each side of the back cover by inserting the plastic opening tool and sliding it along the edge.
    • Remove the back panel by lifting the panel away from the device.
  3. HP eStation Zeen Motherboard Replacement: 3 단계, 이미지 1/1
    • Disconnect battery clip with plastic opening tool.
    • The clip is very fragile.
  4. HP eStation Zeen Motherboard Replacement: 4 단계, 이미지 1/1
    • Disconnect the speaker terminal with the plastic opening tool.
  5. HP eStation Zeen Motherboard Replacement: 5 단계, 이미지 1/1
    • Disconnect the the volume button clip with metal spudger tool.
    • The clip is fragile.
  6. HP eStation Zeen Motherboard Replacement: 6 단계, 이미지 1/1
    • Disconnect the ground wire from the motherboard with tweezers.
  7. HP eStation Zeen Motherboard Replacement: 7 단계, 이미지 1/2 HP eStation Zeen Motherboard Replacement: 7 단계, 이미지 2/2
    • Remove the two 6mm Phillips screws with Phillips #0 screwdriver.
  8. HP eStation Zeen Motherboard Replacement: 8 단계, 이미지 1/2 HP eStation Zeen Motherboard Replacement: 8 단계, 이미지 2/2
    • Pry off the clips that hold the motherboard down with the plastic spudger.
  9. HP eStation Zeen Motherboard Replacement: 9 단계, 이미지 1/2 HP eStation Zeen Motherboard Replacement: 9 단계, 이미지 2/2
    • Lift motherboard up to expose the ribbons on the back.
    • Lift the grey tabs to disconnect the ribbons with plastic spudger.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
dalton hale
회원 가입일: 09/26/16
503 평판
안내서 4개 작성하였습니다
USF Tampa, Team 16-4, Eyestone Fall 2016 USF Tampa, Team 16-4, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S16G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 7
전체 시간: 539
