주요 콘텐츠로 건너뛰기
HP eStation Zeen Speaker Replacement
필요한 것
  1. HP eStation Zeen Speaker Replacement, Speaker: 1 단계, 이미지 1/3 HP eStation Zeen Speaker Replacement, Speaker: 1 단계, 이미지 2/3 HP eStation Zeen Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Remove the rubber screw caps using a metal spudger.
    • Remove the two 6mm screw using a Phillips #0 screwdriver.
  2. HP eStation Zeen Speaker Replacement: 2 단계, 이미지 1/3 HP eStation Zeen Speaker Replacement: 2 단계, 이미지 2/3 HP eStation Zeen Speaker Replacement: 2 단계, 이미지 3/3
    • Unclip each side by inserting the plastic opening tool and slide it along the edges.
    • Remove the back panel by lifting the panel away from the device.
  3. HP eStation Zeen Speaker Replacement: 3 단계, 이미지 1/1
    • Disconnect battery clip.
    • The clip is very fragile.
  4. HP eStation Zeen Speaker Replacement: 4 단계, 이미지 1/1
    • Disconnect the speaker wires from the terminal using a plastic opening tool.
    • Be careful the plastic connector is fragile
  5. HP eStation Zeen Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the two 6mm screws using a Phillips #0 screwdriver.
결론
Jack Clark
회원 가입일: 09/26/16
119 평판
안내서 1개 작성함
USF Tampa, Team 16-4, Eyestone Fall 2016 USF Tampa, Team 16-4, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S16G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 176
