주요 콘텐츠로 건너뛰기
HP iPAQ H2200 faceplate replacement
필요한 것
  1. HP iPAQ H2200 faceplate replacement, Battery: 1 단계, 이미지 1/1
    • Press and slide the battery cover tab to remove battery cover.
  2. HP iPAQ H2200 faceplate replacement: 2 단계, 이미지 1/2 HP iPAQ H2200 faceplate replacement: 2 단계, 이미지 2/2
    • Pull on the black tab to lift the battery out of the battery compartment.
  3. HP iPAQ H2200 faceplate replacement, Main Board: 3 단계, 이미지 1/1
    • Remove the stylus by sliding it out of the slot.
  4. HP iPAQ H2200 faceplate replacement: 4 단계, 이미지 1/1
    • Remove the CF card by sliding it out of the slot at the top of the device.
  5. HP iPAQ H2200 faceplate replacement: 5 단계, 이미지 1/1
    • Press down and push the black side strips toward the top of the device to remove them.
  6. HP iPAQ H2200 faceplate replacement: 6 단계, 이미지 1/3 HP iPAQ H2200 faceplate replacement: 6 단계, 이미지 2/3 HP iPAQ H2200 faceplate replacement: 6 단계, 이미지 3/3
    • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
  7. HP iPAQ H2200 faceplate replacement: 7 단계, 이미지 1/2 HP iPAQ H2200 faceplate replacement: 7 단계, 이미지 2/2
    • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
  8. HP iPAQ H2200 faceplate replacement: 8 단계, 이미지 1/1
    • Open the LCD connector, where the orange strip attaches to the main board.
  9. HP iPAQ H2200 faceplate replacement: 9 단계, 이미지 1/1
    • Carefully remove the orange LCD strip from the connector.
  10. HP iPAQ H2200 faceplate replacement: 10 단계, 이미지 1/1
    • Unscrew the 2 screws located at each top corner of the main board.
  11. HP iPAQ H2200 faceplate replacement: 11 단계, 이미지 1/1
    • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
  12. HP iPAQ H2200 faceplate replacement, LCD Screen: 12 단계, 이미지 1/1
    • Unscrew the two bottom screws on LCD screen that were previously located under the main board.
  13. HP iPAQ H2200 faceplate replacement: 13 단계, 이미지 1/2 HP iPAQ H2200 faceplate replacement: 13 단계, 이미지 2/2
    • Press on side tabs to loosen and remove the LCD screen.
  14. HP iPAQ H2200 faceplate replacement, Faceplates: 14 단계, 이미지 1/1
    • Remove the faceplate by unscrewing the green screw located on the top right of the front faceplate.
결론
Tyler Andrews
회원 가입일: 01/13/10
209 평판
안내서 5개 작성하였습니다
Cal Poly, Team 4-12, Forte Winter 2010 Cal Poly, Team 4-12, Forte Winter 2010 회원
CPSU-FORTE-W10S4G12
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,520
