주요 콘텐츠로 건너뛰기
HP iPAQ H2200 motherbaord replacement
필요한 것
  1. HP iPAQ H2200 motherbaord replacement, Battery: 1 단계, 이미지 1/1
    • Press and slide the battery cover tab to remove battery cover.
  2. HP iPAQ H2200 motherbaord replacement: 2 단계, 이미지 1/2 HP iPAQ H2200 motherbaord replacement: 2 단계, 이미지 2/2
    • Pull on the black tab to lift the battery out of the battery compartment.
  3. HP iPAQ H2200 motherbaord replacement, Main Board: 3 단계, 이미지 1/1
    • Remove the stylus by sliding it out of the slot.
  4. HP iPAQ H2200 motherbaord replacement: 4 단계, 이미지 1/1
    • Remove the CF card by sliding it out of the slot at the top of the device.
  5. HP iPAQ H2200 motherbaord replacement: 5 단계, 이미지 1/1
    • Press down and push the black side strips toward the top of the device to remove them.
  6. HP iPAQ H2200 motherbaord replacement: 6 단계, 이미지 1/3 HP iPAQ H2200 motherbaord replacement: 6 단계, 이미지 2/3 HP iPAQ H2200 motherbaord replacement: 6 단계, 이미지 3/3
    • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
  7. HP iPAQ H2200 motherbaord replacement: 7 단계, 이미지 1/2 HP iPAQ H2200 motherbaord replacement: 7 단계, 이미지 2/2
    • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
  8. HP iPAQ H2200 motherbaord replacement: 8 단계, 이미지 1/1
    • Open the LCD connector, where the orange strip attaches to the main board.
  9. HP iPAQ H2200 motherbaord replacement: 9 단계, 이미지 1/1
    • Carefully remove the orange LCD strip from the connector.
  10. HP iPAQ H2200 motherbaord replacement: 10 단계, 이미지 1/1
    • Unscrew the 2 screws located at each top corner of the main board.
  11. HP iPAQ H2200 motherbaord replacement: 11 단계, 이미지 1/1
    • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Tyler Andrews
회원 가입일: 01/13/10
209 평판
안내서 5개 작성하였습니다
Cal Poly, Team 4-12, Forte Winter 2010 Cal Poly, Team 4-12, Forte Winter 2010 회원
CPSU-FORTE-W10S4G12
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 4,648
