이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Pull on the black tab to lift the battery out of the battery compartment.
Remove the CF card by sliding it out of the slot at the top of the device.
Press down and push the black side strips toward the top of the device to remove them.
Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
Open the LCD connector, where the orange strip attaches to the main board.
Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
다른 4명이 해당 안내서를 완성하였습니다.
