소개
Many of these steps are the same for screen replacement.
도구
부품
지정된 부품이 없습니다.
To begin the disassembly of the device, place it on a flat surface with the screen facing down.
Carefully remove the back cover using the plastic opening tool against the grooves along the sides of the iPAQ.
At this point, a yellow ribbon will be connecting both the front and back panels of the device. Carefully use the plastic opening tool to detach the ribbon from the connector pins.
거의 끝나갑니다!
결론
