주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
HP iPAQ H3850 Screen Replacement
필요한 것
  1. HP iPAQ H3850 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • To begin the disassembly of the device, place it on a flat surface with the screen facing down.
  2. HP iPAQ H3850 Screen Replacement: 2 단계, 이미지 1/1
    • Remove the four screws found on the back cover of the device.
  3. HP iPAQ H3850 Screen Replacement: 3 단계, 이미지 1/1
    • Carefully remove the back cover using the spudger against the grooves along the sides of the iPAQ.
  4. HP iPAQ H3850 Screen Replacement: 4 단계, 이미지 1/1
    • At this point, a yellow ribbon will be connecting both the front and back panels of the device. Carefully use the plastic opening tool to detach the ribbon from the connector pins.
  5. HP iPAQ H3850 Screen Replacement: 5 단계, 이미지 1/1
    • Remove SD card on top of device by pushing and then releasing.
  6. HP iPAQ H3850 Screen Replacement: 6 단계, 이미지 1/1
    • Remove the ribbon cable connected to display logic board by pulling the plastic clips on both sides towards top of device.
    • Use plastic opening tool to carefully pull brown ribbon cable from connector.
  7. HP iPAQ H3850 Screen Replacement: 7 단계, 이미지 1/3 HP iPAQ H3850 Screen Replacement: 7 단계, 이미지 2/3 HP iPAQ H3850 Screen Replacement: 7 단계, 이미지 3/3
    • Use the plastic opening tool to carefully remove the display logic board from its housing.
    • Unplug connector from the opposite end of the display logic board.
    • Completely remove component.
  8. HP iPAQ H3850 Screen Replacement: 8 단계, 이미지 1/1
    • Flip up black plastic clip on large ribbon cable connector located towards center of mother board.
    • Use plastic opening tool to carefully remove ribbon cable from connector.
  9. HP iPAQ H3850 Screen Replacement: 9 단계, 이미지 1/1
    • Locate clear/grey ribbon cable in bottom corner of device.
    • Gently pry cable out of connector with plastic opening tool.
    • Use hands or tweezers to remove if necessary.
  10. HP iPAQ H3850 Screen Replacement: 10 단계, 이미지 1/1
    • Use your hands to gently unplug the speaker and microphone connectors from the mother board.
  11. HP iPAQ H3850 Screen Replacement: 11 단계, 이미지 1/1
    • Remove three small screws from each corner of the motherboard using phillips head screwdriver.
    • Use your hands/plastic opening tool to carefully lift the mother board out of housing.
    • Place the motherboard to the side.
  12. HP iPAQ H3850 Screen Replacement: 12 단계, 이미지 1/1
    • Locate the four blue plastic clips surrounding the square screen housing.
    • Pry back clips with your hands.
    • Use the plastic opening tool to remove the entire screen assembly from the housing.
    • Insert new screen into device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Carson Horton
회원 가입일: 04/05/15
131 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 338
