주요 콘텐츠로 건너뛰기
HP iPAQ HW6515 Flash LED Bulb Replacement
필요한 것
  1. HP iPAQ HW6515 Flash LED Bulb Replacement, Battery: 1 단계, 이미지 1/3 HP iPAQ HW6515 Flash LED Bulb Replacement, Battery: 1 단계, 이미지 2/3 HP iPAQ HW6515 Flash LED Bulb Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the HP iPAQ HW6515 over with the screen facing down.
    • Take the back cover off by pressing on the small silver button while pulling back then up on the case.
    • Place the back of the case aside for now.
  2. HP iPAQ HW6515 Flash LED Bulb Replacement: 2 단계, 이미지 1/1
    • Remove the battery by pulling up on the black tab.
  3. HP iPAQ HW6515 Flash LED Bulb Replacement, Flash LED Bulb: 3 단계, 이미지 1/3 HP iPAQ HW6515 Flash LED Bulb Replacement, Flash LED Bulb: 3 단계, 이미지 2/3 HP iPAQ HW6515 Flash LED Bulb Replacement, Flash LED Bulb: 3 단계, 이미지 3/3
    • Unscrew the four screws using the T6 hexagonal star screwdriver.
    • Unscrew the middle screw using the Phillips 00 screwdriver.
    • "Warranty VOID if broken" sticker might be covering the middle screw, if this is the case, peel it off to reveal the screw.
  4. HP iPAQ HW6515 Flash LED Bulb Replacement: 4 단계, 이미지 1/3 HP iPAQ HW6515 Flash LED Bulb Replacement: 4 단계, 이미지 2/3 HP iPAQ HW6515 Flash LED Bulb Replacement: 4 단계, 이미지 3/3
    • Use the plastic opening tool to pry apart the covers along the bottom of the phone.
    • Slide the plastic opening tool along the seam until the two halves of the case separate.
  5. HP iPAQ HW6515 Flash LED Bulb Replacement: 5 단계, 이미지 1/2 HP iPAQ HW6515 Flash LED Bulb Replacement: 5 단계, 이미지 2/2
    • Unplug the sensor wire that connects the two halves of the case before pulling the two halves apart. Not doing so will damage the sensor wire.
  6. HP iPAQ HW6515 Flash LED Bulb Replacement: 6 단계, 이미지 1/3 HP iPAQ HW6515 Flash LED Bulb Replacement: 6 단계, 이미지 2/3 HP iPAQ HW6515 Flash LED Bulb Replacement: 6 단계, 이미지 3/3
    • Gently pull off the black rubber square covering the LED light.
    • The LED is now exposed.
    • Wedge the plastic opening tool under the LED to pop it out and expose its wire.
    • Using your index finger and thumb, unplug the wire from the phone and remove the LED.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Steven Vo
회원 가입일: 04/02/12
33 평판
안내서 1개 작성함
Cal Poly, Team 15-17, Forte Spring 2012 Cal Poly, Team 15-17, Forte Spring 2012 회원
CPSU-FORTE-S12S15G17
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 1,148
