주요 콘텐츠로 건너뛰기
HP iPAQ HW6515 Motherboard Replacement
필요한 것
  1. HP iPAQ HW6515 Motherboard Replacement, Battery: 1 단계, 이미지 1/3 HP iPAQ HW6515 Motherboard Replacement, Battery: 1 단계, 이미지 2/3 HP iPAQ HW6515 Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the HP iPAQ HW6515 over with the screen facing down.
    • Take the back cover off by pressing on the small silver button while pulling back then up on the case.
    • Place the back of the case aside for now.
  2. HP iPAQ HW6515 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the battery by pulling up on the black tab.
  3. HP iPAQ HW6515 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/3 HP iPAQ HW6515 Motherboard Replacement, Motherboard: 3 단계, 이미지 2/3 HP iPAQ HW6515 Motherboard Replacement, Motherboard: 3 단계, 이미지 3/3
    • Unscrew the four outside screws using the T6 hexagonal star screwdriver.
    • Unscrew the inside middle screw using a Phillips 00 screwdriver.
    • "Warranty VOID if broken" sticker might be covering the middle screw, if this is the case, peel it off to reveal the screw.
  4. HP iPAQ HW6515 Motherboard Replacement: 4 단계, 이미지 1/3 HP iPAQ HW6515 Motherboard Replacement: 4 단계, 이미지 2/3 HP iPAQ HW6515 Motherboard Replacement: 4 단계, 이미지 3/3
    • Use the plastic opening tool to pry apart the covers along the bottom of the phone.
    • Slide the plastic opening tool along the seam until the two halves of the case separate.
  5. HP iPAQ HW6515 Motherboard Replacement: 5 단계, 이미지 1/3 HP iPAQ HW6515 Motherboard Replacement: 5 단계, 이미지 2/3 HP iPAQ HW6515 Motherboard Replacement: 5 단계, 이미지 3/3
    • Unplug the sensor wire that connects the two halves of the case before pulling the two halves apart. Not doing so will damage the sensor wire.
  6. HP iPAQ HW6515 Motherboard Replacement: 6 단계, 이미지 1/1
    • Use a 00 Phillips screwdriver to remove the three small screws holding down the motherboard.
  7. HP iPAQ HW6515 Motherboard Replacement: 7 단계, 이미지 1/1
    • Peel back the black tape that covers the connector.
    • It is fine if one of the left connectors comes off along with the tape.
  8. HP iPAQ HW6515 Motherboard Replacement: 8 단계, 이미지 1/3 HP iPAQ HW6515 Motherboard Replacement: 8 단계, 이미지 2/3 HP iPAQ HW6515 Motherboard Replacement: 8 단계, 이미지 3/3
    • Lift the black tab to a 45 degree angle.
    • Use a screwdriver to get under the tape and disconnect the tape from the black tab.
  9. HP iPAQ HW6515 Motherboard Replacement: 9 단계, 이미지 1/2 HP iPAQ HW6515 Motherboard Replacement: 9 단계, 이미지 2/2
    • Gently pry the motherboard out of the front casing, bottom first.
    • Disconnect the wire connecting the motherboard to the front casing. Using too much force will damage this wire.
결론
Ashley Schaefer
회원 가입일: 04/04/12
83 평판
안내서 2개 작성하였습니다
Cal Poly, Team 15-17, Forte Spring 2012 Cal Poly, Team 15-17, Forte Spring 2012 회원
CPSU-FORTE-S12S15G17
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 1,237
