부품
부품은 필요하지 않습니다.
  1. Slide the silver release tab up and simultaneously lift the cover up from the left side.
    • Slide the silver release tab up and simultaneously lift the cover up from the left side.
  2. Push the tab from left to right to remove the cover.
    • Push the tab from left to right to remove the cover.
  3. Now lift the battery up and away from the device to remove it.
    • Now lift the battery up and away from the device to remove it.
  4. Remove the four silver screws (T5 x .25 in).
    • Remove the four silver screws (T5 x .25 in).
  5. Remove the single black screw (T5 x .125 in) beneath the HP sticker.
    • Remove the single black screw (T5 x .125 in) beneath the HP sticker.
  6. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  7. Next, use your plastic removal tool to separate the gray back from the black center piece. For better results, start the separation at the corner piece.
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  8. Remove the back case.
    • Remove the back case.
  9. Now that the back cover is removed, remove the small screw (#00 Philips x .17) to the left of the SD card slot
    • Now that the back cover is removed, remove the small screw (#00 Philips x .17) to the left of the SD card slot
  10. Next you will need to unlock and remove the ribbon cable Carefully pull back on both sides of the brown bar using metal tweezers, unlocking the cable and slipping it out of the connector
    • Next you will need to unlock and remove the ribbon cable
    • Carefully pull back on both sides of the brown bar using metal tweezers, unlocking the cable and slipping it out of the connector
    • The bar, connector, and cable are fragile components that can be easily broken
  11. Next you need to remove the wire off the bottom of the mother board The easiest method is to use some metal tweezers and grip the plug close to the connector.
    • Next you need to remove the wire off the bottom of the mother board
    • The easiest method is to use some metal tweezers and grip the plug close to the connector.
    • Make sure all these connections are properly disconnected before separation of the motherboard
  12. Next use your plastic removal tool and separate the silver front case from the black frame.
    • Next use your plastic removal tool and separate the silver front case from the black frame.
  13. Remove the 4 screws along the bottom of the faceplate
    • Remove the 4 screws along the bottom of the faceplate
    • They are #00 Philips head screws
  14. Once removed you can easily separate the keys from the body. Once removed you can easily separate the keys from the body.
    • Once removed you can easily separate the keys from the body.
  15. once the joypad key have been removed use the tweezers to carefully maneuver the wire out of its clip releasing the battery once the joypad key have been removed use the tweezers to carefully maneuver the wire out of its clip releasing the battery
    • once the joypad key have been removed use the tweezers to carefully maneuver the wire out of its clip releasing the battery
결론
다른 한 분이 해당 안내서를 완성하였습니다.
John Pagliero
회원 가입일: 2011년 01월 27일
886 평판
안내서 7개 작성하였습니다
Cal Poly, Team 3-39, Regan Winter 2011 Cal Poly, Team 3-39, Regan Winter 2011 회원
CPSU-REGAN-W11S3G39
4 회원들
안내서 7개 작성하였습니다
This guide is AWESOME.. Thanks! I have an iPAQ 1945 h1900, but this guide was the exact same for my device. I got as far as the taking the battery out without removing the 5th screw beneath the "warranty void" sticker. My only issue--do you know where to get the replacement battery?
Drew Stafford - 답글
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 2,379
