주요 콘텐츠로 건너뛰기
HP iPAQ h4155 Backup Battery Replacement
필요한 것
  1. HP iPAQ h4155 Backup Battery Replacement, Battery: 1 단계, 이미지 1/1
    • While sliding the silver release tab up, simultaneously lift the cover up from the left side.
  2. HP iPAQ h4155 Backup Battery Replacement: 2 단계, 이미지 1/1
    • Push the tab left to right to remove the cover.
  3. HP iPAQ h4155 Backup Battery Replacement: 3 단계, 이미지 1/1
    • Now, lift the battery up and away from the device to remove it.
  4. HP iPAQ h4155 Backup Battery Replacement, Back Case: 4 단계, 이미지 1/1
    • Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
  5. HP iPAQ h4155 Backup Battery Replacement: 5 단계, 이미지 1/1
    • Remove the single black screw that is located beneath the HP sticker with the T5 Torx Screwdriver.
  6. HP iPAQ h4155 Backup Battery Replacement: 6 단계, 이미지 1/2 HP iPAQ h4155 Backup Battery Replacement: 6 단계, 이미지 2/2
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. HP iPAQ h4155 Backup Battery Replacement: 7 단계, 이미지 1/1
    • Remove the back case.
  8. HP iPAQ h4155 Backup Battery Replacement, Face Plate: 8 단계, 이미지 1/1
    • Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
  9. HP iPAQ h4155 Backup Battery Replacement: 9 단계, 이미지 1/2 HP iPAQ h4155 Backup Battery Replacement: 9 단계, 이미지 2/2
    • Next, unlock and remove the ribbon cable.
    • Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
    • The bar, the connector, and the cable are fragile components that are easily broken.
  10. HP iPAQ h4155 Backup Battery Replacement: 10 단계, 이미지 1/2 HP iPAQ h4155 Backup Battery Replacement: 10 단계, 이미지 2/2
    • Next, remove the wire from the bottom of the mother board.
    • The easiest method is to use metal tweezers and grip the plug closest to the connector.
    • Make sure all the connections are properly disconnected before separation from the motherboard.
  11. HP iPAQ h4155 Backup Battery Replacement: 11 단계, 이미지 1/1
    • Next, use a plastic removal tool and separate the silver front case from the black frame.
  12. HP iPAQ h4155 Backup Battery Replacement, JoyPad buttons: 12 단계, 이미지 1/1
    • Remove the 4 screws along the bottom of the faceplate
    • They are #00 Philips head screws
  13. HP iPAQ h4155 Backup Battery Replacement: 13 단계, 이미지 1/2 HP iPAQ h4155 Backup Battery Replacement: 13 단계, 이미지 2/2
    • Once removed you can easily separate the keys from the body.
  14. HP iPAQ h4155 Backup Battery Replacement, Backup Battery: 14 단계, 이미지 1/2 HP iPAQ h4155 Backup Battery Replacement, Backup Battery: 14 단계, 이미지 2/2
    • once the joypad key have been removed use the tweezers to carefully maneuver the wire out of its clip releasing the battery
결론
다른 4명이 해당 안내서를 완성하였습니다.
John Pagliero
회원 가입일: 01/27/11
942 평판
안내서 7개 작성하였습니다
댓글 2개
This guide is AWESOME.. Thanks! I have an iPAQ 1945 h1900, but this guide was the exact same for my device. I got as far as the taking the battery out without removing the 5th screw beneath the "warranty void" sticker. My only issue--do you know where to get the replacement battery?
Drew Stafford - 답글
IMPORTANT. The back up battery does not show charge immediately ( i don't know why ) Id read something before. When in April 2023 i swapped the old B U Batt for a known good one from another ipaq. At the end of the job . The level of charge on the b.up was zero. I charged the main batt to 100% then removed the ipaq from the charger and left it for a couple of hours . When I next checked it there was 100% on both batts....
Ron - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 3,513
