주요 콘텐츠로 건너뛰기
HP iPAQ h4155 Face Plate Replacement
필요한 것
  1. HP iPAQ h4155 Face Plate Replacement, Battery: 1 단계, 이미지 1/1
    • While sliding the silver release tab up, simultaneously lift the cover up from the left side.
  2. HP iPAQ h4155 Face Plate Replacement: 2 단계, 이미지 1/1
    • Push the tab left to right to remove the cover.
  3. HP iPAQ h4155 Face Plate Replacement: 3 단계, 이미지 1/1
    • Now, lift the battery up and away from the device to remove it.
  4. HP iPAQ h4155 Face Plate Replacement, Back Case: 4 단계, 이미지 1/1
    • Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
  5. HP iPAQ h4155 Face Plate Replacement: 5 단계, 이미지 1/1
    • Remove the single black screw that is located beneath the HP sticker with the T5 Torx Screwdriver.
  6. HP iPAQ h4155 Face Plate Replacement: 6 단계, 이미지 1/2 HP iPAQ h4155 Face Plate Replacement: 6 단계, 이미지 2/2
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. HP iPAQ h4155 Face Plate Replacement: 7 단계, 이미지 1/1
    • Remove the back case.
  8. HP iPAQ h4155 Face Plate Replacement, Face Plate: 8 단계, 이미지 1/1
    • Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
  9. HP iPAQ h4155 Face Plate Replacement: 9 단계, 이미지 1/2 HP iPAQ h4155 Face Plate Replacement: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Next, unlock and remove the ribbon cable.
    • Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
    • The bar, the connector, and the cable are fragile components that are easily broken.
  10. HP iPAQ h4155 Face Plate Replacement: 10 단계, 이미지 1/2 HP iPAQ h4155 Face Plate Replacement: 10 단계, 이미지 2/2
    • Next, remove the wire from the bottom of the mother board.
    • The easiest method is to use metal tweezers and grip the plug closest to the connector.
    • Make sure all the connections are properly disconnected before separation from the motherboard.
  11. HP iPAQ h4155 Face Plate Replacement: 11 단계, 이미지 1/1
    • Next, use a plastic removal tool and separate the silver front case from the black frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
John Pagliero
회원 가입일: 01/27/11
942 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,411
