주요 콘텐츠로 건너뛰기
HP iPAQ h4155 LCD screen replacement
필요한 것
  1. HP iPAQ h4155 LCD screen replacement, Battery: 1 단계, 이미지 1개 중 1개
    • While sliding the silver release tab up, simultaneously lift the cover up from the left side.
  2. HP iPAQ h4155 LCD screen replacement: 2 단계, 이미지 1개 중 1개
    • Push the tab left to right to remove the cover.
  3. HP iPAQ h4155 LCD screen replacement: 3 단계, 이미지 1개 중 1개
    • Now, lift the battery up and away from the device to remove it.
  4. HP iPAQ h4155 LCD screen replacement, Back Case: 4 단계, 이미지 1개 중 1개
    • Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
  5. HP iPAQ h4155 LCD screen replacement: 5 단계, 이미지 1개 중 1개
    • Remove the single black screw that is located beneath the HP sticker with the T5 Torx Screwdriver.
  6. HP iPAQ h4155 LCD screen replacement: 6 단계, 이미지 2개 중 1개 HP iPAQ h4155 LCD screen replacement: 6 단계, 이미지 2개 중 2개
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. HP iPAQ h4155 LCD screen replacement: 7 단계, 이미지 1개 중 1개
    • Remove the back case.
  8. HP iPAQ h4155 LCD screen replacement, Face Plate: 8 단계, 이미지 1개 중 1개
    • Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
  9. HP iPAQ h4155 LCD screen replacement: 9 단계, 이미지 2개 중 1개 HP iPAQ h4155 LCD screen replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Next, unlock and remove the ribbon cable.
    • Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
    • The bar, the connector, and the cable are fragile components that are easily broken.
  10. HP iPAQ h4155 LCD screen replacement: 10 단계, 이미지 2개 중 1개 HP iPAQ h4155 LCD screen replacement: 10 단계, 이미지 2개 중 2개
    • Next, remove the wire from the bottom of the mother board.
    • The easiest method is to use metal tweezers and grip the plug closest to the connector.
    • Make sure all the connections are properly disconnected before separation from the motherboard.
  11. HP iPAQ h4155 LCD screen replacement: 11 단계, 이미지 1개 중 1개
    • Next, use a plastic removal tool and separate the silver front case from the black frame.
  12. HP iPAQ h4155 LCD screen replacement, Touch LCD Screen: 12 단계, 이미지 2개 중 1개 HP iPAQ h4155 LCD screen replacement, Touch LCD Screen: 12 단계, 이미지 2개 중 2개
    • Now that the front cover is removed we can detach the screen
    • Remove the ribbon connector by pulling gently on the silver top. It will snap off the mother board.
    • The ribbon cable and connector can be easily removed if you genetly lift up the motherboard to create a small gap
  13. HP iPAQ h4155 LCD screen replacement: 13 단계, 이미지 3개 중 1개 HP iPAQ h4155 LCD screen replacement: 13 단계, 이미지 3개 중 2개 HP iPAQ h4155 LCD screen replacement: 13 단계, 이미지 3개 중 3개
    • Now the screen can be removed
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
John Pagliero
회원 가입일: 01/27/11
957 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 13
전체 시간: 1,732
