필요한 것
While sliding the silver release tab up, simultaneously lift the cover up from the left side.
Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
Now that the front cover is removed we will need to disconnect the LCD screen from the mother board. Pull the LCD connection out of the slot to properly disconnect.
다른 한 분이 해당 안내서를 완성하였습니다.
