주요 콘텐츠로 건너뛰기
HP iPAQ h4155 Motherboard Replacement
필요한 것
  1. HP iPAQ h4155 Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • While sliding the silver release tab up, simultaneously lift the cover up from the left side.
  2. HP iPAQ h4155 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Push the tab left to right to remove the cover.
  3. HP iPAQ h4155 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Now, lift the battery up and away from the device to remove it.
  4. HP iPAQ h4155 Motherboard Replacement, Back Case: 4 단계, 이미지 1개 중 1개
    • Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
  5. HP iPAQ h4155 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the single black screw that is located beneath the HP sticker with the T5 Torx Screwdriver.
  6. HP iPAQ h4155 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 HP iPAQ h4155 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. HP iPAQ h4155 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the back case.
  8. HP iPAQ h4155 Motherboard Replacement, Face Plate: 8 단계, 이미지 1개 중 1개
    • Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
  9. HP iPAQ h4155 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 HP iPAQ h4155 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Next, unlock and remove the ribbon cable.
    • Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
    • The bar, the connector, and the cable are fragile components that are easily broken.
  10. HP iPAQ h4155 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 HP iPAQ h4155 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Next, remove the wire from the bottom of the mother board.
    • The easiest method is to use metal tweezers and grip the plug closest to the connector.
    • Make sure all the connections are properly disconnected before separation from the motherboard.
  11. HP iPAQ h4155 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Next, use a plastic removal tool and separate the silver front case from the black frame.
  12. HP iPAQ h4155 Motherboard Replacement, Motherboard: 12 단계, 이미지 1개 중 1개
    • Now that the front cover is removed we will need to disconnect the LCD screen from the mother board. Pull the LCD connection out of the slot to properly disconnect.
  13. HP iPAQ h4155 Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Next we will need to remove the last wire from the motherboard
    • The easiest method is to grab and pull with metal tweezers near the bottom of the plug near the connector.
  14. HP iPAQ h4155 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 HP iPAQ h4155 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Finally the mother board can be removed from the center black frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
John Pagliero
회원 가입일: 01/27/11
957 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 1,227
