주요 콘텐츠로 건너뛰기
HP rp5700 Hard Drive Replacement
  1. HP rp5700 Hard Drive Replacement, Cover Removal: 1 단계, 이미지 1개 중 1개
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 HP rp5700 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. HP rp5700 Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 HP rp5700 Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 HP rp5700 Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
  4. HP rp5700 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 1개 HP rp5700 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 2개
    • Using your right hand, grip the CD drive and lift it up to a 90 degree position.
  5. HP rp5700 Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 HP rp5700 Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Use your hand, whichever you prefer, to grip the two cords on the CD drive and remove the two cords by pulling up.
    • Repeat the same process to remove the two cords connected to the Hard Drive.
  6. HP rp5700 Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Use your right index finger to pull forward the green flap on the side of the hard drive.
    • At the same time as you are lifting the green flap, use your left hand to lift the hard drive up and out.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alyssa Briones
회원 가입일: 01/21/14
1,720 평판
안내서 9개를 작성함
Cal Poly, Team 6-23, Maness Winter 2014 Cal Poly, Team 6-23, Maness Winter 2014 회원
CPSU-MANESS-W14S6G23
4 회원들
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 11
전체 시간: 4,006
