이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Make sure the computer is unplugged.
Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
Set the desktop down horizontally with the front side facing you.
Hold the desktop with two hands by grasping both sides of the desktop.
Press the buttons on both sides using your index fingers.
Slide the top cover about an inch forward using your thumb to push it towards you.
Make sure that the bottom is still secured by both hands.
Lay the desktop back on the table and pull the case forward as far as it can go.
Lift the cover up and off.
Using your hand, grip the Optical Drive and lift it up into a 45 degree angle.
Disconnect the power supply cord and the SATA cord using your hands to pull them out.
Using your left index finger, lift the upper green tab found on the left side of the green piece.
Using your opposite hand, use your fingers to push the back of the drive forward and slide it out away from the desktop.
Grasp the optical drive with your right or left hand and pull the drive out towards you.
다른 한 분이 해당 안내서를 완성하였습니다.
