소개
Is your image flickering, shattered or discolored ? Replacing your screen could solve these problems. Always uses caution when working with glass, a scratch or slight fall could completely ruin a screen.
필요한 것
Lift the screen assembly from the plastic housing from the corners.
Should it be "underneath one of the device's corners"?
You might want to add a note letting users know that they should be careful of the wires attaching the assembly to the housing.
You may also want to note that the card for the power button slides out when you lift this assembly so the user might need to be told to slide the card back into its slot when installing the new screen. ( A picture of this would be a good idea)
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
I have an HP laptop. How can i fix the screen to my laptop? Will it be the same thing? And how would i know what screen to get for it? Thanks.
Contact hp corporate they can sell u a replacement screen or a local electronic repair store or even a monitor of equal size should work and assembly is very simular but components are much more sensitive and fragile be careful and best of luck i love comouter repair
