주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
부품
지정된 부품이 없습니다.
  1. Remove the 2 Screw covers from the lower sides of the Bezel
    • Remove the 2 Screw covers from the lower sides of the Bezel
  2. Remove the 2 Screws using a PH#1
    • Remove the 2 Screws using a PH#1
  3. Use a pick along the top and sides of the bezel to start removing the bezel. Use your fingers to gently pry from the bottom of the bezel while pulling up. Bezel is very fragile.
    • Use a pick along the top and sides of the bezel to start removing the bezel. Use your fingers to gently pry from the bottom of the bezel while pulling up. Bezel is very fragile.
  4. Remove the 2 screws from the top of the frame, One on each side.
    • Remove the 2 screws from the top of the frame, One on each side.
  5. Remove the 4 screws holding the LCD to the frame. 2 on each side.
    • Remove the 4 screws holding the LCD to the frame. 2 on each side.
  6. Lay the LCD down on the keyboard and remove the webcam cable (if you have one) and remove the video cable.
    • Lay the LCD down on the keyboard and remove the webcam cable (if you have one) and remove the video cable.
결론
Brent Norris
회원 가입일: 2017년 05월 06일
387 평판
안내서 1개 작성함
Brents Computer Repair Brents Computer Repair 회원
Business
1 회원
안내서 1개 작성하였습니다
Video guide How to disassemble HP Compaq G71 https://youtu.be/TsoP3EdbHz8
Viktorya - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 27
