주요 콘텐츠로 건너뛰기
HP-Compaq G71-329WM LCD Replacement
필요한 것
  1. HP-Compaq G71-329WM LCD Replacement, LCD: 1 단계, 이미지 1/1
    • Remove the 2 Screw covers from the lower sides of the Bezel
  2. HP-Compaq G71-329WM LCD Replacement: 2 단계, 이미지 1/1
    • Remove the 2 Screws using a PH#1
  3. HP-Compaq G71-329WM LCD Replacement: 3 단계, 이미지 1/1
    • Use a pick along the top and sides of the bezel to start removing the bezel. Use your fingers to gently pry from the bottom of the bezel while pulling up. Bezel is very fragile.
  4. HP-Compaq G71-329WM LCD Replacement: 4 단계, 이미지 1/1
    • Remove the 2 screws from the top of the frame, One on each side.
  5. HP-Compaq G71-329WM LCD Replacement: 5 단계, 이미지 1/1
    • Remove the 4 screws holding the LCD to the frame. 2 on each side.
  6. HP-Compaq G71-329WM LCD Replacement: 6 단계, 이미지 1/1
    • Lay the LCD down on the keyboard and remove the webcam cable (if you have one) and remove the video cable.
결론
Brent Norris
회원 가입일: 05/06/17
559 평판
안내서 1개 작성함
Brents Computer Repair Brents Computer Repair 회원
Business
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Video guide How to disassemble HP Compaq G71 https://youtu.be/TsoP3EdbHz8
Viktorya - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 64
