주요 콘텐츠로 건너뛰기
HP-Pavillion 500-424 PC Series CPU Fan Replacement
필요한 것
  1. HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: 1 단계, 이미지 1/2 HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: 1 단계, 이미지 2/2
    • Lay the tower down carefully on its right side, with the vents pointing up.
  2. HP-Pavillion 500-424 PC Series CPU Fan Replacement: 2 단계, 이미지 1/3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: 2 단계, 이미지 2/3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: 2 단계, 이미지 3/3
    • Use the flat head #6 screwdriver bit to unscrew the tower casing.
    • Very gently slide the case towards you.
    • Lift the casing up and gently place it off to the side.
  3. HP-Pavillion 500-424 PC Series CPU Fan Replacement: 3 단계, 이미지 1/3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: 3 단계, 이미지 2/3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: 3 단계, 이미지 3/3
    • Unplug the fan from the motherboard by gently grasping the connector and slowing pulling up.
    • Remove each screw from the fan using the Phillips head screwdriver bit.
    • Place the screws in a cup, they are very small and can be lost easily.
    • Remove the old fan from the CPU.
결론
To reassemble your device, follow these instructions in reverse order. Now you should feel confident replacing the CPU fan in your HP desktop without any difficulties.
다른 2명이 해당 안내서를 완성하였습니다.
Amanda Milby
회원 가입일: 09/13/18
177 평판
안내서 1개 작성함
Pasco Hernando, Team S5-G73, Prince Fall 2018 Pasco Hernando, Team S5-G73, Prince Fall 2018 회원
PHSC-PRINCE-F18S5G73
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 35
전체 시간: 1,919
