주요 콘텐츠로 건너뛰기
HP17-x116dx Fan Replacement
필요한 것
  1. HP17-x116dx Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off your computer before starting. Place the back of your computer face up to ensure you are facing the battery.
  2. HP17-x116dx Fan Replacement: 2 단계, 이미지 1/2 HP17-x116dx Fan Replacement: 2 단계, 이미지 2/2
    • Find the battery latches.
    • Slide the latches towards the center of the device.
  3. HP17-x116dx Fan Replacement: 3 단계, 이미지 1/2 HP17-x116dx Fan Replacement: 3 단계, 이미지 2/2
    • Remove the old battery by pulling it towards you. Replace the old battery with the new one and follow these steps in reverse order to reassemble your device.
  4. HP17-x116dx Fan Replacement, Fan: 4 단계, 이미지 1/2 HP17-x116dx Fan Replacement, Fan: 4 단계, 이미지 2/2
    • Remove the fourteen 8 mm screws with the Phillips #1 screwdriver.
  5. HP17-x116dx Fan Replacement: 5 단계, 이미지 1/2 HP17-x116dx Fan Replacement: 5 단계, 이미지 2/2
    • Once the screws are removed, carefully remove the CD player port.
  6. HP17-x116dx Fan Replacement: 6 단계, 이미지 1/2 HP17-x116dx Fan Replacement: 6 단계, 이미지 2/2
    • Once you have removed the CD player port, use the spudger tool to carefully remove the back panel.
  7. HP17-x116dx Fan Replacement: 7 단계, 이미지 1/1
    • Once you remove the back panel you will see your fan on the bottom left side of your laptop.
  8. HP17-x116dx Fan Replacement: 8 단계, 이미지 1/3 HP17-x116dx Fan Replacement: 8 단계, 이미지 2/3 HP17-x116dx Fan Replacement: 8 단계, 이미지 3/3
    • To remove the fan, start by unplugging the fan from the motherboard.
  9. HP17-x116dx Fan Replacement: 9 단계, 이미지 1/3 HP17-x116dx Fan Replacement: 9 단계, 이미지 2/3 HP17-x116dx Fan Replacement: 9 단계, 이미지 3/3
    • Once the fan is unplugged from the motherboard, remove the 6 mm screws with a Phillips #1 screwdriver that are connecting the fan to the laptop. Remove the fan.
  10. HP17-x116dx Fan Replacement: 10 단계, 이미지 1/1
    • Once the fan is removed, you will see the hot plate that transfers the heat from the laptop to the fan. You will need to add thermal paste to the hot plate before placing your replacement fan back on.
  11. HP17-x116dx Fan Replacement: 11 단계, 이미지 1/1
    • Once you have placed your thermal paste on the hot plate, take your replacement fan and place it back where the old fan was. To reassemble your laptop, follow these steps in reverse order.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Samantha Orozco
회원 가입일: 03/22/18
235 평판
안내서 1개 작성함
Sam Houston State, Team S17-G1, Blackburne Spring 2018 Sam Houston State, Team S17-G1, Blackburne Spring 2018 회원
SHSU-BLACKBURNE-S18S17G1
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Hola, se le puede instalar una memoria optane a éste modelo?
Henry - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 10
전체 시간: 1,324
