주요 콘텐츠로 건너뛰기
HTC Amaze Loud Speaker Replacement
필요한 것
  1. HTC Amaze Loud Speaker Replacement, Battery: 1 단계, 이미지 1/2 HTC Amaze Loud Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
  2. HTC Amaze Loud Speaker Replacement: 2 단계, 이미지 1/1
    • Once you locate the battery, look for a notch below it.
    • Gently insert your fingernails into the notch.
    • Lift the battery out of its recess.
  3. HTC Amaze Loud Speaker Replacement, HTC Amaze Back Panel Disassembly: 3 단계, 이미지 1/3 HTC Amaze Loud Speaker Replacement, HTC Amaze Back Panel Disassembly: 3 단계, 이미지 2/3 HTC Amaze Loud Speaker Replacement, HTC Amaze Back Panel Disassembly: 3 단계, 이미지 3/3
    • Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
    • One of the Screws may have a tape attached to it that says void. Removing this screw will void the devices warranty.
  4. HTC Amaze Loud Speaker Replacement: 4 단계, 이미지 1/3 HTC Amaze Loud Speaker Replacement: 4 단계, 이미지 2/3 HTC Amaze Loud Speaker Replacement: 4 단계, 이미지 3/3
    • Proceed to remove the back housing by using the spudger to gently unclip each clip holding the back housing in place and then lift the outer edges of the back housing
    • If you're having trouble opening the back try using the spudger to gently pry all around the panel before you attempt to remove it.
  5. HTC Amaze Loud Speaker Replacement: 5 단계, 이미지 1/2 HTC Amaze Loud Speaker Replacement: 5 단계, 이미지 2/2
    • Now simply remove the back panel by gently pulling. This will make it easier to access the devices internal components.
  6. HTC Amaze Loud Speaker Replacement, Loud Speaker: 6 단계, 이미지 1/3 HTC Amaze Loud Speaker Replacement, Loud Speaker: 6 단계, 이미지 2/3 HTC Amaze Loud Speaker Replacement, Loud Speaker: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Turn the back panel over to access its interior, and locate the loudspeaker marked in the picture.
    • Remove it by gently pulling with the precision tweezers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Akshat Shah
회원 가입일: 09/26/16
368 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-3, Eyestone Fall 2016 USF Tampa, Team 16-3, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S16G3
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 132
