소개
The loudspeaker is located within the back panel of the device. This makes it relatively simple to access.
필요한 것
Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
