주요 콘텐츠로 건너뛰기
HTC Desire 310 Micro USB Port Replacement
필요한 것
    • The video guide will show you how to replace the micro usb port properly. Repeat each step shown in the recording to complete the repair.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alex Sander
회원 가입일: 02/28/17
38,219 평판
안내서 202개 작성하였습니다
댓글 4개
Can’t see a blasted thing clearly. How do you make the pin connections on the motherboard?
Keith Weisberger - 답글
Hello! Please be more precise, the pin connections are already on the motherboard, if you haven’t got one you’ve probably tear them down.
Alex Sander -
Can barely see anything. Camera lense is filthy, picture not in focus and dark. How do you make the pin connections? it appears that you do so only after soldering the rear legs to the motherboard, but I can’t see how you manage it
It would be nice if you had explained what you were doing during the removal. What was that goo you put on it and how did it work to remove the old part?
andrew - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 709
