주요 콘텐츠로 건너뛰기
HTC Desire 530 Battery Replacement
필요한 것
  1. HTC Desire 530 Battery Replacement, Battery: 1 단계, 이미지 1/2 HTC Desire 530 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Use the plastic opening tools to remove the plastic speaker covers that are attached through an adhesive layer.
    • They may be difficult to peel off and you might want to consider loosening the adhesive layer by running a hair dryer or a heat gun over it briefly to allow them to peel off easily.
  2. HTC Desire 530 Battery Replacement: 2 단계, 이미지 1/3 HTC Desire 530 Battery Replacement: 2 단계, 이미지 2/3 HTC Desire 530 Battery Replacement: 2 단계, 이미지 3/3
    • Use the T5 Torx screwdriver to remove the four screws in each corner.
    • Make sure to take out any SD cards, located on the left side of the phone before proceeding to the next step.
    • Use the plastic opening tool to pry the front of the device off. Fully go around the front with the plastic opening tool before attempting to pull it off.
  3. HTC Desire 530 Battery Replacement: 3 단계, 이미지 1/3 HTC Desire 530 Battery Replacement: 3 단계, 이미지 2/3 HTC Desire 530 Battery Replacement: 3 단계, 이미지 3/3
    • Dislocate the small piece with the wires connected using a nylon spudger.
    • Loosen the adhesive layer for the battery by running a hair dryer over it briefly. After the adhesive is loosened you can pry the battery out with a plastic opening tool.
  4. HTC Desire 530 Battery Replacement: 4 단계, 이미지 1/2 HTC Desire 530 Battery Replacement: 4 단계, 이미지 2/2
    • After prying, simply lift the battery up and out of the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alyssa
회원 가입일: 10/24/18
205 평판
안내서 1개 작성함
UMASSD-PEAK-F18S3G2 UMASSD-PEAK-F18S3G2 회원
Community
3 회원들
안내서 10개 작성하였습니다
댓글 2개
Mi phone is sealed no scrows on my phone HTC Desire 530 so haw can i get the Battery out
robert jelley - 답글
My phone is sealed so awe can i get the Battery out it is HTC desire 530
robert jelley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 17
전체 시간: 4,187
