주요 콘텐츠로 건너뛰기
HTC Desire 530 Micro USB Port Replacement
필요한 것
  1. HTC Desire 530 Micro USB Port Replacement, Micro USB Port: 1 단계, 이미지 1/1
    • Remove the four 1.2mm screws in each corner.
    • Use the suction cup and plastic opening tool to pry the screen from the body.
  2. HTC Desire 530 Micro USB Port Replacement: 2 단계, 이미지 1/1
    • Gently pry the battery up at these three spots, and disconnect the power cables attached.
  3. HTC Desire 530 Micro USB Port Replacement: 3 단계, 이미지 1/1
    • You can then fold the battery back like so, and that will give you access to the screw.
  4. HTC Desire 530 Micro USB Port Replacement: 4 단계, 이미지 1/1
    • Use the screwdriver to remove the 1.2 mm screw at the bottom of the phone.
  5. HTC Desire 530 Micro USB Port Replacement: 5 단계, 이미지 1/1
    • Once the screw and the black plastic backing are removed the daughterboard pulls right out.
  6. HTC Desire 530 Micro USB Port Replacement: 6 단계, 이미지 1/1
    • In order to fix the Micro USB Port, the entire daughterboard will need to be replaced because all connections are soldered in.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Eric Blackstock
회원 가입일: 10/24/18
403 평판
안내서 2개 작성하였습니다
UMASSD-PEAK-F18S3G2 UMASSD-PEAK-F18S3G2 회원
Community
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 9
전체 시간: 625
